MPEG2 Western Arc shutoff | Page 16 | SatelliteGuys.US
We are watching one of those historical dish events.
148w was the first slot they left after satellite failures (abandoned permit). It did not need to be replaced after the very versatile ciel 2 came into service.
Then they moved off their 77w Quetzat satellite (apparantly because the two other eastern slots fullfilled their needs.
Now we see a similar move off Ciel 2 at 129w with the two other western slots fullfilling their needs.
And more quietly, the moves from the 105 and 121
Reactions: charlesrshell
A commercial place might use 2 larger single dishes, one on 110 and the other on 119, to minimize weather downtime. Those could use either dp dual or single. Actually a D500 into a DP switch could use DP singles (if they made those, don't remember), DP duals (only need one of the 2 outputs per LNBF), DP Twin or DPP Twin.
I've seen that. 3 500 Dishes w/DP singles/Duos for each WA Sat to a 44 Switch
We are going back to d500 and new dual lnbs. However 1000.2 dishes can still be used with the triple lnb. After July 21st receivers will stop looking for the 129.
Ok, that just seems like a lot of retooling for no gain. A modified LNBF ala the EA 1000.2 LNBF would seem to be a lower cost change to accommodate the sat count reduction.
Will Dish add my Locals in HD to either 110 or 119? Right now they are on 61.5. If they do , I can get rid of the wing satellite which has problems when the foliage gets thick. My Sd locals are still on 110. My satellite signal status box still show 119,110,129,61.5.
Which DMA are you in? It's not uncommon for the HD locals to be on one arc, and the SD locals to be on the other.
His profile says Lubbock Texas
Thanks... As part of the WA transition, I suppose Dish may upgrade the signal from MPEG-2 SD to MPEG-4 HD, so we'll just have to wait and see it seems. I expect it would be a low priority until all the bulk changes are completed in relation to leaving 129.
No, there are no changes to the Eastern Arc.
BTW, here's the update on 129
Starting on 7/11, orbital 129 will no longer carry content for the majority of customers. Technicians will continue to see 129 in the checkswitch results until 7/21.
All content currently provided by orbital 129 will be fully transitioned to orbitals 110/119 as of 7/21.
Not to mention the fact that there are probably thousands and thousands of 1000.2 dishes sitting in warehouses waiting to be shipped out.
To be fair, there could be a warehouse full of D500 out there as well (albeit covered in cobwebs lol).
The DPP Twin isn’t made anymore as far as I know but Dish Mexico uses D500’s to catch 77w, or at least they did 10 years ago last time I went south of the border.
It looks like all the changes occurred overnight! As I was going through the channels to see if everything moved, I see that channel 6064 is currently mapped to an old app that sends the receiver into an endless loop instead of going to the SiriusXM music channel. I can't seem to get out of it, even by resetting the receiver because it remembers 6064 was the last channel I tuned into. So hopefully that will resolve itself once the transition is complete during the overnight hours!
I do expect Dish will remove 129 sat support from all receivers soon, correct? It appears like everything has moved off of 129 sat except for a few local channels in some places lol.
90 minutes later the phantom app is still there, and it is on 6004 as well :)
Jul 20th, 129 will basically cease to exist. Software updates (not sure about VIPs) will remove the 129 from Check Switches
For those of you interested, here are the 208 changes I came across this morning:
ChannelTypeNetworkNowWas
72SDValue119, TP 16129, TP 32
73SDQVC3110, TP 05110, TP 10
81SDICTV110, TP 10119, TP 16
82SDFETV119, TP 19110, TP 10
84SDBuyTV110, TP 05129, TP 23
85SDEPIC119, TP 16110, TP 10
86SDMALL119, TP 16110, TP 10
87SDSmart119, TP 16110, TP 21
94SDRenew119, TP 16110, TP 10
95SDDeal119, TP 16110, TP 10
104SDValue (same as 72)119, TP 16129, TP 32
123SDMALL (same as 86)119, TP 16110, TP 10
161SDMTV2119, TP 16119, TP 19
163SDMTV Classic110, TP 10110, TP 21
177SDCartoon Network (West)110, TP 10110, TP 05
178SDNickToons119, TP 16119, TP 19
181SDTeen Nick119, TP 16119, TP 19
210SDCSPAN110, TP 05110, TP 16
211SDCSPAN2110, TP 10119, TP 16
217SDGrit119, TP 19110, TP 05
218SDBinge110, TP 16129, TP 26
220SDMALL (same as 86)119, TP 16110, TP 10
221SDExtra119, TP 16110, TP 10
223SDRenew119, TP 16110, TP 10
224SDEpic119, TP 16110, TP 10
225SDSale119, TP 16110, TP 05
228SDYouTV119, TP 16110, TP 10
230SDICTV110, TP 10119, TP 16
237SDLAFF110, TP 16110, TP 10
240SDJustice110, TP 10129, TP 27
243SDFM110, TP 10119, TP 16
245SDBuzzr119, TP 16110, TP 05
252SDLaw and Crime110, TP 16129, TP 26
253SDCozi110, TP 03110, TP 10
255SDQVC2110, TP 05110, TP 10
256SDBible110, TP 05110, TP 21
257SDSBN110, TP 03110, TP 21
258SDTBNI110, TP 03110, TP 05
260SDTBN110, TP 05110, TP 16
261SDEWTN110, TP 03110, TP 16
262SDCTN110, TP 10110, TP 16
263SDDaystar110, TP 05119, TP 16
264SDImpact110, TP 03129, TP 32
265SDVictory110, TP 03110, TP 21
275SDYouTV119, TP 16110, TP 10
276SDSmart119, TP 16110, TP 21
277SDRenew119, TP 16110, TP 10
278SDDeal119, TP 16110, TP 10
279SDCGTNN110, TP 03110, TP 16
282SDValue119, TP 16129, TP 32
283SDBuyTV110, TP 05129, TP 23
284SDRectv110, TP 10129, TP 27
286SDNASA110, TP 10110, TP 16
288SDExtra119, TP 16110, TP 10
291SDStart119, TP 16110, TP 05
292SDMGM+D110, TP 03119, TP 16
329SDTMC-W110, TP 10110, TP 21
330SDTMCXW110, TP 10110, TP 21
343SDEncore Action110, TP 03110, TP 05
345SDEncore Black110, TP 03129, TP 26
346SDEncore Classic110, TP 03129, TP 27
347SDEncore Family110, TP 03129, TP 26
360SDGrio110, TP 16119, TP 16
373SDGet TV110, TP 10110, TP 21
377SDMoviePlex110, TP 10110, TP 21
387SDFMC110, TP 16110, TP 10
390SDOutside Television110, TP 16129, TP 26
393SDPursuit TV110, TP 10110, TP 16
394SDWorld Fishing Network110, TP 03129, TP 23
398SDFanDuel Racing110, TP 05129, TP 23
399SDFanDuel Racing110, TP 10129, TP 23
407SDLonghorn Network110, TP 05110, TP 21
409SDPAC 12 Network119, TP 16129, TP 23
821SDCLAN110, TP 03129, TP 27
823SDBaby 1110, TP 10110, TP 16
824SDBaby110, TP 05129, TP 27
826SDWAPAA110, TP 10129, TP 27
828SDUnivision West110, TP 05110, TP 21
831SDMLMDS110, TP 16129, TP 26
832SDCentro110, TP 16110, TP 10
834SDPSNES110, TP 16110, TP 05
836SDTelemundo110, TP 16110, TP 05
837SDTLNOV110, TP 16110, TP 21
839SDAnt3110, TP 16129, TP 27
841SDNTEL110, TP 16129, TP 26
842SDCrcol110, TP 03129, TP 27
843SDHistory Channel Spanish110, TP 16110, TP 05
844SDNat Geo Mundo110, TP 03110, TP 05
846SDDS Fam110, TP 16129, TP 26
848SDMLNIO110, TP 16110, TP 05
851SDCuba Max TV110, TP 05110, TP 16
852SDEstrella TV110, TP 03110, TP 10
863SDMXCNL110, TP 16129, TP 26
864SDCsony119, TP 16129, TP 27
865SDCine Latino110, TP 16129, TP 27
880SDHITN110, TP 05110, TP 16
881SDV-ME110, TP 05119, TP 16
883SDValue119, TP 16129, TP 32
884SDCGTNE110, TP 05110, TP 16
890SDVDRLA110, TP 16110, TP 21
891SDTRS3110, TP 16129, TP 27
892MusicVmari119, TP 19119, TP 16
893MusicMojito119, TP 19119, TP 16
924MusicAud2119, TP 19119, TP 16
925MusicAud3119, TP 19119, TP 16
931MusicAud9119, TP 19119, TP 16
933MusicAud10119, TP 19119, TP 16
934MusicAud11119, TP 19119, TP 16
935MusicAud12119, TP 19119, TP 16
936MusicAud13119, TP 19119, TP 16
937MusicAud14119, TP 19119, TP 16
938MusicAud15119, TP 19119, TP 16
939MusicAud16119, TP 19119, TP 16
950MusicCD1119, TP 19119, TP 16
951MusicCD2119, TP 19119, TP 16
956MusicCD7119, TP 19119, TP 16
959MusicCD10119, TP 19119, TP 16
960MusicCD11119, TP 19119, TP 16
961MusicCD12119, TP 19119, TP 16
962MusicCD13119, TP 19119, TP 16
963MusicCD14119, TP 19119, TP 16
966MusicCD17119, TP 19119, TP 16
967MusicCD18119, TP 19119, TP 16
968MusicCD19119, TP 19119, TP 16
974MusicCD25119, TP 19119, TP 16
977MusicCD28119, TP 16119, TP 19
978MusicCD29119, TP 16119, TP 19
980MusicCD31110, TP 05110, TP 16
998SDDish Business Info119, TP 16129, TP 21
4385SDTBN - Inspire110, TP 03110, TP 05
6002MusicSXM02110, TP 21129, TP 29
6004MusicSXM04110, TP 21119, TP 16
6005MusicSXM05110, TP 21110, TP 03
6006MusicSXM06110, TP 21110, TP 03
6007MusicSXM07110, TP 21110, TP 03
6008MusicSXM08110, TP 03129, TP 29
6009MusicSXM09110, TP 21129, TP 23
6010MusicSXM10110, TP 21119, TP 16
6014MusicSXM14110, TP 03129, TP 23
6015MusicSXM15110, TP 03129, TP 20
6016MusicSXM16110, TP 21129, TP 20
6019MusicSXM19110, TP 03129, TP 23
6020MusicSXM20110, TP 03129, TP 32
6021MusicSXM21110, TP 03129, TP 23
6022MusicSXM22110, TP 03129, TP 17
6023MusicSXM23110, TP 03129, TP 23
6024MusicSXM24110, TP 03129, TP 32
6025MusicSXM25110, TP 03129, TP 32
6026MusicSXM26119, TP 16129, TP 29
6027MusicSXM27119, TP 16129, TP 17
6028MusicSXM28119, TP 16129, TP 17
6029MusicSXM29119, TP 16129, TP 23
6030MusicSXM30119, TP 16129, TP 23
6032MusicSXM32110, TP 03129, TP 23
6033MusicSXM33110, TP 03129, TP 23
6034MusicSXM34110, TP 03129, TP 23
6035MusicSXM35110, TP 03129, TP 29
6036MusicSXM36110, TP 03129, TP 29
6037MusicSXM37110, TP 03129, TP 17
6038MusicSXM38110, TP 03129, TP 17
6039MusicSXM39110, TP 03129, TP 23
6040MusicSXM40110, TP 03129, TP 29
6041MusicSXM41110, TP 03129, TP 29
6042MusicSXM42110, TP 21129, TP 29
6043MusicSXM43110, TP 03129, TP 32
6044MusicSXM44110, TP 03129, TP 29
6045MusicSXM45119, TP 16129, TP 23
6046MusicSXM46110, TP 21129, TP 23
6047MusicSXM47110, TP 21119, TP 16
6048MusicSXM48110, TP 21129, TP 23
6049MusicSXM49110, TP 21129, TP 23
6050MusicSXM50110, TP 21119, TP 16
6051MusicSXM51110, TP 03129, TP 23
6052MusicSXM52119, TP 16129, TP 23
6053MusicSXM53110, TP 03129, TP 29
6054MusicSXM54110, TP 03129, TP 32
6055MusicSXM55110, TP 21119, TP 16
6056MusicSXM56110, TP 21129, TP 29
6057MusicSXM57110, TP 21129, TP 29
6058MusicSXM58110, TP 21129, TP 17
6059MusicSXM59110, TP 21129, TP 23
6060MusicSXM60110, TP 21129, TP 23
6062MusicSXM62110, TP 21129, TP 23
6063MusicSXM63110, TP 03129, TP 32
6064MusicSXM64110, TP 21129, TP 23
6065MusicSXM65110, TP 03129, TP 23
6066MusicSXM66110, TP 21129, TP 23
6067MusicSXM67119, TP 16129, TP 23
6068MusicSXM68110, TP 21129, TP 29
6069MusicSXM69119, TP 16129, TP 23
6070MusicSXM70110, TP 21129, TP 23
6071MusicSXM71110, TP 03129, TP 23
6072MusicSXM72110, TP 03129, TP 29
6073MusicSXM73110, TP 03129, TP 23
6074MusicSXM74110, TP 21129, TP 29
6075MusicSXM75110, TP 21129, TP 23
6076MusicSXM76110, TP 03129, TP 29
6091MusicSXM91110, TP 21119, TP 16
6094MusicSXM94110, TP 21119, TP 16
6095MusicSXM95110, TP 21119, TP 16
6096MusicSXM96110, TP 21119, TP 16
9393SD3ABN110, TP 05129, TP 21
9403SDBYU TV110, TP 05110, TP 16
9410SDLink TV110, TP 10110, TP 16
9411SDEnlace TV110, TP 05110, TP 16
9415SDFree Speech TV110, TP 10110, TP 16
9458SDBuyTV110, TP 05129, TP 23
9532SDICTV110, TP 10119, TP 16
I have not been able to document the following channel changes as I don't subscribe to them, but I know almost all of them switched. If anyone is subscribed to them and can tell me where they are, I would appreciate it!
233SDSuperstation - KTLA129, TP 32
234SDSuperstation - WPIX129, TP 32
235SDSuperstation - KWGN129, TP 32
236SDSuperstation - WSBK129, TP 32
238SDSuperstation - WWOR110, TP 01
281SDBBC World News129, TP 26
285SDDOG TV110, TP 21
322SDShowtime Extreme119, TP 16
323SDShowtime Showcase110, TP 01
328SDTMCXE119, TP 18
333SDFLIX110, TP 05
353SDStarz Cinema119, TP 12
355SDStarz In Black119, TP 12
362SDBET Gospel110, TP 10
363SDBET Soul110, TP 10
364SDCMT Music129, TP 26
365SDBET Jams110, TP 10
366SDMTVU129, TP 26
368SDNick Music110, TP 10
391SDFox Soccer Plus129, TP 26
