New Genie UI now in CE testing | Page 2 | SatelliteGuys.US
I see a few pictures over on the edge forums. Still only 1 hour guide info. Waste even more area by putting channel number, channel name, and then channel name graphics.
If you registered for the Cutting Edge section their you'd be able to view it.
I just get this error message. I have had the account for awhile.
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Sos you do what it tells you to do at. Cutting Edge: Start here
Thanks for that info. The new software looks cool, I kind of wish they would have added an extra half hour. Or will you have the option to add how many hours the guide gets? Thanks for the link. Is this the same look and feel across all their TV services when they mentioned when the news broke about the cloud DVR? Also is this only on the HR-44 and above? I know they said the HR-34 wont get it. Will the other H/HR boxes get it? When will it be deployed? Thanks.
Too many questions too early. As of right now only the HR44/54 and HS-17 are testing over there
best lnb to upgrade to SWM
STARZ ENCORE ESPAÑOL
