Anyone notice anything different with the 0x1000 update that popped up this morning?
How are can you force a download for an HS-17? Thanks anyone’s help or responseI noticed 0x1000 in the stream Wednesday morning for the HR54-200, and HS17-100. It was in the stream between 3am and 7am ET Thursday and Friday, for all versions of the HR44, HR54, and HS17. I was tempted to force a download but decided against it.
You can't, you have to be on the list to have it sent to you.How are can you force a download for an HS-17? Thanks anyone’s help or response
I did the CLEARMYBOX in the search and all the logos were gone because it probably had to redownload them but they came back. Did you do anything at all to your system or they just randomly disappeared?I noticed that all the logos for for channels in the guide and the info bar have disappeared. It just lists the name of the channel twice. Is anyone else experiencing this? Thanks for the help!
Thank you very muchYou can't, you have to be on the list to have it sent to you.
I forced a download of 0x1001 this morning and found it to be more responsive than 0x0FFC. Some of the logos are using very small fonts (I have a 65” television and 20/15 vision) between Channels 535 and 554. The small font issue is sporadic above this point. I have not experienced any missing logos. Have not noticed much changed in functionality other than the responsiveness.
How do you force download on HR 44?
I'd just restart the box 3 times in a row or do the CLEARMYBOX in the search and it will reboot and should reload them. If you choose to restart your box 3 times in a row, make sure you do them in a row and not let the box sit for a while after each reset.No I haven't done anything to my system. Just randomly disappeared when I turned on the tv yesterday.
Limited time offer
