i would add for the (3) restarts in a row - wait for tv pic to come back then (red) button whack it--starting with the TV pic on 1st wack - then continue 2 & 3
Personally, I'd just use the Clearmybox and be done with it.i would add for the (3) restarts in a row - wait for tv pic to come back then (red) button whack it--starting with the TV pic on 1st wack - then continue 2 & 3
Or Clearmybox2 depending on your situation.Me too I just use Clearmybox too
Ones for regular software, the other for beta software.What’s the difference between clearmybox and clearmybox2?
Yeah ...Ones for regular software, the other for beta software.
It is two times in a row and they just have to be within 30 min of each otherI'd just restart the box 3 times in a row or do the CLEARMYBOX in the search and it will reboot and should reload them. If you choose to restart your box 3 times in a row, make sure you do them in a row and not let the box sit for a while after each reset.
This assumes the new software is in the queue for downloading. Otherwise you will get the previous national release.Restart the receiver (when the "BLUE" light goes dark) upon the first sign of the blue light(re-boot) from the remote (using IR remote*) point it at the receiver "Press" 0 2 4 6 8
*I find using a IR remote gets better results - if you miss it and it starts boot up- press the red button and try again
That's correct, but I didn't want the poster thinking he would necessarily be getting the new software. Jimbo, can you post a link that shows when the new software is in the queue? Pretty sure you have it.they just asked HOW to do it- not when
Seems like weve been at FFC for a long time now ... not complaining as its working pretty well, but after giving us new software most weekends ....
I know its because of the Holidays, probably be one this weekend.
really, I didn'think it was THAT long, but maybe so. I know they skipped the last 2 weeks plus the 1st weekend of the new year.I've Been on FFC since 12/2/17 - The holidays have been going on for a very long time
I saw 1000 out there, but it wasn't there when I was awake and I'm not gonna purposely wake up to check.0x1001 has been rolling out between 3 am and 7 am ET since January 4th.
Limited time offer
