Do you have "IAMANEDGECUTTER" enabled?Did the re boot and clearmybox still still no demand.
Type the dash, then search for IAMANEDGECUTTER in the box. Nothing will happen. To see if it worked, look and see if you have a "misc. options" menu at the bottom on the left when you press menu.I don’t know how do I enabled iamanedgecuttter.
Yes sir. I edited the post above since you wrote in case you missed it.I did it show “misc.options. Is that all I need to do.
Yes, that tells you that you have successfully d/l the edgecutter portion and your programming should come in sooner than later.I did it show “misc.options. Is that all I need to do.
Correct, but in this case the reason is when you enable it, the backend servers that the genie connects to are changed to the CE servers, when running CE it's recommended to be connecting back to those vs the standard servers. Enabling this has helped many get the logos, posters and on-demand back etc.Type the dash, then search for IAMANEDGECUTTER in the box. Nothing will happen. To see if it worked, look and see if you have a "misc. options" menu at the bottom on the left when you press menu.
This process allows you to send issues to Directv, which can only be done on the CE forum. Everyone who downloads CE software should at least read the propaganda at the CE forum and see what the program is all about. Ignore all the crap about their exclusivity and the moderaters can be hostile... Just join to read about it and report and you're good.
Yes, if you really want it, you can download software over night, but it will come to your recvr when D* has your area scheduled, so its up to you.I keep hoping that the new guide will show up on my HR44, but I still have the old guide. Is there anything I can do myself to get it to load or do I just have to wait on it?
Here's my experience with the new UI: it has made my genie 2 so slow and buggy that even with multiple resets it's still acting up...
Sent from my XT1710-02 using the SatelliteGuys app!
Limited time offer
