I have the 1079 update on my HR54 With no complaints
Sent from my SM-G965U using Tapatalk
What about the Menu ? The Guide, Yes, you get use to (I never had a problem with the guide (once the tweaks were done) ... but the Menu is terrible ...As said by others, it just takes time to get used to the new interface, once the shock wears off and you start to look around it's not bad at all. As of 0X1037 most things are fluid and are bug free, the newer CE versions improve things slightly even more but nothing major. So I just say to folks who hate the new interface to just give it more time.
That doesn't improve ....
With how bad it is that you cannot see all your folders on the screen when going to it .... you have to go WAY to the right to do most things ...
Whats worse is the fact that when you hit the guide button to get there, it starts you inside of a folder already .....
They could at least fix that and make you at the top of the stuff on the LEFT side so YOU can choose where you want to go without ALREADY being inside a folder.
The only recording list sort options I see are either FIFO or by alphabetical order.They start you on the left, annoys me as well, but again now more used to it, just don't like the delays around moving around the menu.
Menu diffidently needs improvement, the sorting of my playlist drives me crazy, I have yet to find a way to sort it, right now it's first in first out unless I reboot the HR, then it's sorted by season / episode. I have't really searched around for a solution, know of one? Or am I crazy and it sorts fine?
You can short the top folder only by alphabetical or latest but when you go into a program that has more then one recording (folder) it's latest only. I would like to be able to sort based on episodes, record date, original air date and so on, right now it's just latest inside a folder.The only recording list sort options I see are either FIFO or by alphabetical order.
Press "0" to select as noted at the top of the list menu.
Sent from my LG-H918 using Tapatalk
DTV / AT&T is betting on the younger crowd but really they are just aligning up the interface with the entire AT&T portfolio and what you see today is becoming more common across all the carriers.they made the font smaller for what? so we can have 7 channels on the guide instead of 6? wow, great improvement! . as far as i can tell, there's nothing substantially better about the new interface. as a matter of fact it's worse. and now my 79 year old mother can't read the guide because the font is too small.
Yeah I've noticed ...You can short the top folder only by alphabetical or latest but when you go into a program that has more then one recording (folder) it's latest only. I would like to be able to sort based on episodes, record date, original air date and so on, right now it's just latest inside a folder.
I would want it to sort by most recent recorded.You can short the top folder only by alphabetical or latest but when you go into a program that has more then one recording (folder) it's latest only. I would like to be able to sort based on episodes, record date, original air date and so on, right now it's just latest inside a folder.
Try running "clearmybox" via a search and select in the search menu, has helped many with slow boxes run quick again. Box will reboot just to note.My main beef is the performance hit. It feels like a PC that’s been “upgraded” to a new OS that requires more horsepower than is available. My HR54 with the old UI was very zippy — now, feels bogged down (doesn’t respond quickly to button presses, etc).
Just downloaded 1080FYI
CE (BETA) 4-20 Friday and 4-21 Saturday 11 PM ET to 3 AM ET Version 0x1080
Sent from my Pixel 2 XL using Tapatalk
Limited time offer
