New Guide UI now rolling out (plus HDR support!) | Page 65 | SatelliteGuys.US
Still no logos. What misc options are you referring too?
At the bottom of your Menu section you'll see Misc Options IF your doing the CE software.
IF your not, you won't see it.
You would want to do a search for
iamanedgecutter
If you want to get into that side of the beta software.
Please tell me I didn’t just get the new Guide? I hit list and got this. I was hoping to wait it out for a while longer yet.
New guide it is. 0x1040 today at 1:54am. So far it’s not at all sluggish, just as fast as before although I’m not seeing these new channel logos everyone is talking about but I assume it takes time to populate. It’s ok I guess, at least I still have the old guide on my other receivers
New Logos take time to populate, sometimes up to a day. A while back it got sluggish after being up and running for a long time, something would start to drag it down like a memory leak but whatever it was it has been fixed.
I got the update Thursday morning. Still no logos in the guide. The other thing that is annoying if you sort your recordings in a different order they will not keep the charge. Is there a way to save the view of the recordings you want without having to press 0 each time to resort them to your liking?
I got 1040 3 days ago. Still no logos
One of three options will fix it
1) reboot
2) "clearmybox" same process as #3 (box will reboot after you search and select)
3) "IAMANEDGECUTTER" (Menu > Search > Select, go out and back in and check for Misc. Options
Adding # 3 works on any build and points the system to different backend DTV servers. Menu > Search > "IAMANEDGECUTTER" Select it, go out of the menu and back and check the bottom, you will see "Misc Options", wait a few hours and see if it repopulates
Doing #2 clears the guide out, but none of your settings, recordings etc, this refreshes guide including the logos and posters. Will take time to download info, logos and posters.
Doing #1 is the easiest but I doubt it will bring them back but rebooting twice in a row, does a mini clear. (not settings just guide like #2 but it's not a full guide clear, partial)
Only try one at a time and wait etc.
Also do a speedtest (settings / Network etc) and make sure you get an 88 code not 87.
Just a guess I guess.
Reactions: whitewolf8214
I just downloaded 1082. Logos in the guide are gone. May try and redownload and see if that brings them back.
Redownload 1082 and still no logos in the guide.
I think the logos in last 4 are much smaller but I never really paid attention.
Sent from my Pixel 2 XL using Tapatalk
Lost logos too but just wait it out, downloading twice will not fix it, make sure to enable the misc options when on CE.
I d/led as well last night (I do them all) ...
I too lost logos, which is shocking as I have had them all along, even when others didn't ... no clue why, but it doesn't matter.
Now, with No Logos ...
I actually like it much better .... I have No Reason to need logos as they just clutter up the guide in my opinion.
I guess I can take it or leave the Logos ... doesn't much matter.
Fwiw, the On Demand IS there ... didn't check last night, but it is there today.
Often times, Logos and OD are tied together.
Also, my Speed test code is 88-690
Same here and the guide is super quick with no logos, OD works too and didn't lose posters, just logos.
Guide_before.jpg Guide_0x1082.jpg I noticed no logos in guide with 0x1082 download as well. But after I looked closer, I noticed it isn't the that the logos in the guide are "gone" or "lost", it is that they have been removed! Please look at the before and the the 0x1082 shots. Before, the channel name was listed below the number with logo to the right (if logo was missing, it would have the channel name there until logo downloaded). But now with 0x1082, the channel number and name are arranged as they were in the old guide, no place for logo.
View attachment 132730 View attachment 132731 I noticed no logos in guide with 0x1082 download as well. But after I looked closer, I noticed it isn't the that the logos in the guide are "gone" or "lost", it is that they have been removed! Please look at the before and the the 0x1082 shots. Before, the channel name was listed below the number with logo to the right (if logo was missing, it would have the channel name there until logo downloaded). But now with 0x1082, the channel number and name are arranged as they were in the old guide, no place for logo.
I did the 1082 last night aswell, had the 1080, and had logos, after 1082 was done, i had no guide logos at all, but DO have logos, in the QuickTune box, where you click the up button when watching tv, to select from of your 9 favorite networks/channels. The logos are on that..
Sent from my iPad using Tapatalk Pro
Question, if I have the CE software installed on the receiver, do I get the NR when its scheduled for my receiver?
Sent from my iPad using SatelliteGuys mobile app
