I didn't figure I would run into any fellow Iowans on here
Hopefully somone is close to you and can help you out.
Larry
Larry
It probably won't make any difference, but I think your longitude should be 85.0, and your latitude should be 45.0.oldrred said:hi again
ok here is what i have so far
on menu i find usals setup as follows:
longtitude angle 084.0
longtitude direction: west
latitude angle: 44.0
latitude direction: south
rotating speed: 0.30
are these correct ?
This should be correct.oldrred said:for the dish , it is pointed south, motor is set at 45 latitude, dish set at 38.5. are these
correct ?
lnb should be standard and set to 10750.oldrred said:next i enter installation and get antenna setting, then a installation screen this is where i get
confused. a lot of sats to chose from for instance, 45 AMC 9 (83w), lnb freq set on universal,
I can't help with the rest of this, as I don't have a CW600s. If you can figure how to enter a TP (transponder), try this:oldrred said:diseqc type set at none, my choices at bottom of screen are: edit satellite, antenna positioning,
mu ltiple satellites setup, start search, when i click start search i get a list 1-31,
#1 freq 00000, pol v, S.R 27500, FEC 3/4, TV 0, RADIO 0. all tv radio have 0.
options at bottom changed to add, delete, edit pid, and tp search. when i press tp search i get a
warning screen asking only fta search ? ok for no, then warning network search, ok for no. then
back to former screen. i click on on start search, my signal strength changes a few times while
searching the back to same screen with same info as before.
when i click ant. positioning i get screen that says motorized system. motor mode set at usals,
transponder at 12011/h/3979/auto
still nothing on quality meter press menu button and get warning no channel press ok and get new
screen, with choice at top of screen of, all channels, fta, and scramble. bottom of screen has
satellite, edit, find, and a-z. if i click on satellite, i get satellite list checked all
satellites. ok back to former screen. edit does nothing. find gets me a screen with a keypad and
bottom screen has ok, back, caps off, and extend. i am lost for sure now!
exit from those screens and back to warning no channel then menu
will someone please explain in detail where i went wrong and how i can get at least a few channels
to watch
captive works cw 600s
same story no matter which satellite i chose
thank you
oh yeah, i would be happy to pay someone to install for me but my money is exhausted as i am disabled and wife is out of work right now just moved in here took everything i had i just need someone who is patient and very knowledgeable on this subject to help me, if someone out there is near me and would be willint trade labor for something i have that would be great,unlikely though
thanx
chris
Othea said:Telstar / IA5 is @ 97W in the sky (that's about 200° Azimut for your location). T5 / IA5 is usually a good place to start.
From your location you can also try AMC4 at approximately 205° Azimut, 36° Elevation for your location. Use Transponder 11822.
Or you can try Galaxy 10R at approximately 231° Azimut, 26° Elevation for your location. Use Transponder 11780 or 11800.
That should give you a few options to start with. After that, well, the sky's the limit! -- Or am I misquoting Hendrix here?
84.67 (or 84.6 if it only allows one digit)oldrred said:good day everyone
ok on my usals setup, (on rcvr)
longtitude angle should be set at ?
Wlongtitude direction ?
45.0latitude angle ?
Nlatitude direction ?
no clue on that onerotating speed (s/') ?
yep you must have hit IA5 (Telstar 5)i finally got reception on one satellite, all mid eastern channels though. i think i may have the above settings incorrect as i can not find any others will someone please tell me what exactly these settings should be. with these setting correct, shouldn't usals automatically be able to find the other sats by itself ? again about 20 miles west of gaylord mich 49611
thanx again for everyones help i would not have made it this far without you!
i am a slow learner but i am sure i will get it eventually!
Iceberg said:global
what is that site suppose to do? I'm confused
Sure, that's fine too.Iceberg said:
oldrred said:rotating speed (s/') ?
Limited time offer
