No HD Signal | SatelliteGuys.US
No HD Signal
I don't know what happened but mine did the same thing. Then it just started working. Maybe yours will too.
I tried rebooting, unplugging the power, anything else I could think of and did not help. After a day or two, I was going to post
it, I decided to try it one more time and it worked. I can't think of anything that I did, that would have made it work.
Good luck.
AL
glad ya got it working
The good thing with the Micro is the a/v cable is hard coded to 480i so if something happens and you accidentally get it to something your TV cant see at least the a/v cables will give you backup option :)
Recording on the Micro HD
microHD Manual
