I will take my time getting this installed.
Be patient. They are still feeding the dog sled team. Aww July and August in Canada, 2 months of poor sking.Sheesh... I'm a patient person, but... Those Canadians are a bit too relaxed.. He waited like 3 days before shipping the HH120 and I'm not gonna get it until next week! I'm supposed to get the 1.2 dish today.
One thing you might want to do when it arrives:.
I installed an HH120 last winter (in Canada) and after two weeks, the alloy casing of the unit was showing discolouration - the start of surface corrosion, I guessed. The HH120 does not have a painted finish like the HH90 (which I also have), so - as I like my gear to look new and shiny for as long as possible - I sprayed it with a coat of clear UV-resistant lacquer.
Another difference between the HH120 and the HH90 is that it moves much slower than the smaller motor - 0.7 degrees per second on 18v IIRC - so you have to develop some extra patience!
And even less on 13V - only 0.4 degrees per second!Another difference between the HH120 and the HH90 is that it moves much slower than the smaller motor - 0.7 degrees per second on 18v IIRC - so you have to develop some extra patience!
And even less on 13V - only 0.4 degrees per second!![]()
Voltage difference from polarity. Horizontal=18 volts, vertical=13 volts.What systems use 13V?
Limited time offer
