The V* receiver is a digital signal OTA only. Even the digital SD channel will be a challenge to reach you. I do not know whether your elevation will be a plus.
mellow19 said:I will be moving in 3 weeks and am having Voom installed. I checked antennaweb and the Digital stations are about 75 miles away from me. Will I still be able to view them from my location?
desidoc said:Can I receive regular UHF and VHF channels if I connect the antenna to TV directly, because I dont have any local HD channels here in yucca valley zip 92284
TRColasanto said:Hi everyone, great forum here. I ordered Voom on Tuesday, it's scheduled to be installed on Monday. I also called today to confirm, and they said it's still a go. All the info here has been great, and hopefully the install won't be too bad. At least I'm prepared.
Anyway, my zip is 21915, I live between Philadelphia and Baltimore, but not too close to either. According to antennaweb.org, there's only one digital station, and it's almost 50 miles away. Does that make it pointless to install the stealth antenna? I'm guessing I won't get any OTA channels without a better antenna? I see from Sean's pictures that even with the amp, the stealth works with yellow, green, and light green, but the channel antennaweb.org shows for me is violet.
Will I get any local channels, even SD, at all?
All this is a little confusing to me, but this forum has helped sort out a lot. I'll post details of my install here too.
ricks said:Newbie - bear with me here. Currently have no digital/HD setup. Doing my research before I pull the trigger. When I do, I intend to go with V*.
Zip is 33411 - suburb of West Palm Beach. All local HD stations are about 9 miles away except the ABC station which is 30 miles away and 170 degrees opposite. All except one of the close stations are UHF. All of the Miami stations are the same direction as the majority of my local stations. They are all about 52 miles away and all UHF.
I live in a townhouse so would prefer to avoid a large outdoor antenna if possible. That, probably, conflicts with my desire to also pull in the Miami stations. Two questions:
1. Is there any method to determine what stations I can receive through experimenting with various antennas - either inside or outside - before I have an OTA tuner? I'm expecting a resounding "NO" on that one.
2. With the above info on stations, any suggestions on whether I should first try V*'s antenna or should I go straight to a different antenna and have it available for the install?
Sean Mota said:Ricks, since you are so close 9 miles away from the stations, you might want to try an indoor silver sensor antenna. Do not know if you will be able to pull the ABC - 30 miles away. Don't know about the 52 miles away with silver sensor. The silver senson is ONLY UHF so keep this in mind. With the Stealth Antenna you won't be able to pull the Miami stations. Stealth Antenna is only 45 miles range with UHF and 30 miles range with VHF. If you decide to go with the outside antenna, you will need a rotor to pull your ABC station. There is no way to experiment and see what works unless you do it. I was in your situation before and decided to go to experiment with Radio Shack antennas. RS has an excellent return policy. No questions asked if it does not work for you. I ended up with the biggest antenna they have because at the time I was pulling stations from CT since in NYC the transmitters went down after 9/11.
klen said:Try voom's Channlemaster 3010 Stealth antenna first, It is fairly decent, and pretty easy on the eyes. If it doesn't pick all of those stations up, call them back. They will install a better antenna at no charge. be forwarned though, that the replacement will be about 8 feet long.........
Sean Mota said:More pictures including the pre-amp.
RickyMac said:I noticed the color zones on your box were yellow and green. The colors recommended for my area are Red, Blue and violet. Does Voom ensure that the correct antenna is installed according to the location?
Limited time offer
