Gr8Reb8 said:This is what he was trying for.
I'll just contribute by imbedding the picture of it.
Bill
dfwarner said:I am currently using voom in the Vernon, Ct area. I did have a lot of problems with the initial installation but seems to be working pretty well right now. I did have a contact at installs inc which I have used to get better results with my installs. I did contact him last week to check on WTIC 61 fox station. He has said that Voom will be adding this within a "day or so". Hopefully this will be moving forward.
pmalve said:WTIC showed up on my guide today. I can't lock on signal though. WVIT comes in at 85 reading on the antenna signal quality meter. What is the antenna signal power for? At least I get the 3 major networks now.
Sean Mota said:Select this channel and tell me what the power number is?
pmalve said:the signal power number is 27
Sean Mota said:That's low to get a lock on the signal. Are you sure the antenna is pointing in the same direction where the transmitter of that channel is. It will help to find out how far is that station from you as well. You maybe out of range or looking in the wrong direction.
dfwarner said:I do get WVIT-30 now. The power level reports about 38-40. I am not getting channel WTIC-61. Power level is around 20. :^((
Antennaweb reports both of these sites to be about 20 miles from my house. I am using the channel master stealth with an rotor I had to add on.
pmalve said:I am not getting WTIC either. Where in CT are you? I live in Bethlehem, I wonder if WTIC antenna is directional? I notice from some of the charts they don't all broadcast in an even circle.
rang1995 said:i found this one good if your hD is UHF range up to 60 miles and it's not so big or noticible on the roof
deeann said:I might be signing up within a few days if the picture stuttering problem mentioned in the other thread clears up or isn't a network-wide issue (and we can see the sat, does anyone around Sacramento, CA have Voom yet?), and I have a question about KMAX-DT UPN 31-1 Sacramento. It doesn't show up in the zap2it guide so does that mean it isn't mapped or could it just be a problem with the guide listing?
Sean Mota said:deeann, if it's not showing up in zap2it it will need to be mapped. If you want send me an email to Sean_Mota@satelliteguys.us with your address and zipcode and brief descriptions of channels that are not mapped and I'll put the request.
I can't comment yet on the stuttering issue since I am not clear what it is or have not seen it. Also, keep in mind that V* has been working on some of these issues.
Limited time offer
