pico 5/8 switch - diplexer question | SatelliteGuys.US
zbroke
33
Fort Worth, Tx
I have a powered Pico 5/8 switch for my Shaw Direct satellite.
I'm ready to use the HD antenna input on that switch to distribute the OTA signal. I was wondering if any of you use this switch and if so which diplexer you are using. Just trying to get the best fit.
I understand that each output line (before it comes in the receiver) will have to have a diplexer weather I use the antenna signal or not. Is this correct?
Thanks!
