Picture distortion when stretching 4:3 image | SatelliteGuys.US
gully
35
Voom's STB appears to be distorting the right side of the image when stretching 4:3 material to fill my 16:9 (Samsung hcn) tv. The distortion does not appear on any other input, nor does it appear with the HD channels.
The distortion slightly stretches the image wide in the area approximate to that not normally used on the right side of the screen (the "pillar box"). It does not distort in the same area on the left side of the screen.
The distortion is noticeable mostly when watching tennis (which I do a lot!). If you look at the attached photo, see the right sideline bend out towards the right of the screen, the result of the image being distorted by stretching.
1. Does anyone else witness this same distortion?
2. Does anyone have any suggestions for addressing it?
That can be because of the angle of the camera to the court... but then again when you stretch 4:3 to widescreen you are asking for distortion. Me I always pillarbox.
Jerry
Jerry
Thanks, Jerry, but no, it's not court/camera angle. The distortion is absolute and constant, visible on every channel (but really noticeable on tennis with the right sideline).
I also get distortion but I am using a 4:3 HDTV. :confused:
When I set the video mode to pillarbox and the TV to "Wide" besides reducing my 32" to something like a 24" I get the full picture. If I have it set to strech and TV on "Normal" I lose part of the picture to the left and right along with the distortion of picture and menus.
I'm guessing that it's a problem with the way that the STB stretches the image. It seems like it would be a really easy fix - but what do I know about this kind of thing.
I think all the complaints of Overscan are actually a problem with the box. That's just a hunch.
When you stretch you get distortion... nothing you or anybody else can do about it. Either watch it like it's supposed to, pillarboxed, or watch it stretched and distorted... your choice.
My question is, why on earth would somebody spend thousands of dollars on a hidef TV for a good quality picture and then stretch 4:3 material and distort it? Makes no sense to me. Oh well to each his own.
Jerry
It looks like you've got a Sammy DLP, so no worries about burn-in. Use pillar boxes to eliminate distortion.
Toshiba has 5 choices of display modes:
0: Native
1: Theater Mode (best for 4:3 has five zones of stretch)
2: Theater Mode (same as 1 with a zoom)
3: Theater Mode (same as 2 with more zoom)
4: Theater Mode (simple stretch)
I can watch 4:3 in Theater Mode (1) with no distortion. It's down right amazing!
Wish Voom could incorporate it.
Unfortunately I can't use it when viewing Voom feeds. For some reason the monitor won't manipulate anything over 480p. Por que?
So I watch in 4:3 or Pillar Mode.
ESPN about to run info on the FREE fight on VOOM!
Firewire ever going to happen?
