any idea why we get a 78% strngth level but 0 quality level?
there is actually 3 itemsI understand about the ebno & where to find it, but under Options 6-4 (System Status on the DSR-315), line D is "signal quality". Line C is "signal strength, line D is "signal quality", and it's in the high 70's on my unit
ebno is to fine tune the dish to get optimum signal. When I do a Shaw install I always ebno # aim. I'll give you an exampleWhat's the relationship between the ebno & the "signal quality" number?
Right now he's just shooting from the hip and "searching the sky".
because the 75e has a screw elevation adjustment so you can make very fine increments of elevation
Per KuSat, this feature has been removed, at least on the newer dishes:
FALL 2009 UPDATE: The long elevation screw shown on the mount (left of the picture) is not included with the 75cm kit anymore. We apologize for any inconvenience this may cause. To adjust elevation on your dish, keep both elevation bolts "snug" and apply pressure at the base of the dish to make adjustments.
thats a scary sentence right there....
damn that sucks...that made adjusting very easy to do
My boat lies north-south
he brought his wife and promised her shopping on the way home
Or, maybe your receiver is broken?
Please tell someone who lives on the desert how you keep the boat oriented north-south while at the same time that the fuel is being used .......
we have nine months of cold wather in Seattle, where I have to run my furnace. It runs on diesel fuel.
The high temperature often way up into the high 70's or low 80's. We've even been over 100. Three times
Even with all the rocking and movement, I still haven't lost satellite lock
there's clearly something else going on with the OP's system
Limited time offer
