RE: [VOOM] 1081 or 720p | SatelliteGuys.US
M
maintenance94
Guest
[VOOM] 1081 or 720p
Happy SuperBowl Friday:
Need input on best format for HD reception........1081 or 720p??
thanks
Ruben
Wouldn=92t native be best?
-----Original Message-----
From: maintenance94 [mailto:plasma50@sbcglobal.net]
Sent: Friday, February 04, 2005 11:24 AM
To: VOOM@yahoogroups.com
Subject: [VOOM] 1081 or 720p
thanks
Ruben
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
* To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=3DUnsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
[Non-text portions of this message have been removed]
Jeff Kraber wrote:
> Wouldn't native be best?
I tried native for a while, but didn't like the longer pauses and flicker I
get when changing channels. I guess it takes my TV a second or two to get
in sync with the box whenever the resolution changes. This is over DVI ->
HDMI -- I did not try in over component.
Anyone else have this problem?
/Sean
FOX sports native format is 720P. So if you want to see it the way they intended it to be seen I'd set the output to 720P. The generally accepted opinion is that 720P is superior for actions orientated programming.
its 1080i or 720p
you know most of the new sets will have native 1080p
but will they make dvds that will play 1080p or will
the industry which is limited to 720p will road block
the better standards as it will make home sources
better than over the air?
> thanks
> Ruben
__________________________________
Do you Yahoo!?
Yahoo! Mail - Find what you need with new enhanced search.
http://info.mail.yahoo.com/mail_250
[VOOM] Re: 1081 or 720p
Hi Jeffrey, I believe the new DVD hi-rez standards will allow 1080p.
You might want to check out one of the DVD forums as I'm sure this is
a hot topic at this point in time.
Still enjoying HDTV under cloudy but clearing Seattle skies, Gill
--- In VOOM@yahoogroups.com, jeffrey gold <jgold49@y...> wrote:
> its 1080i or 720p
> > thanks
> > Ruben
> Do you Yahoo!?
programming.
storageset
This message was posted via http://www.satelliteguys.us by storageset
My TV only receives 1080i. Any idea what kind of PQ I can expect using
cable?
Vicki
Vicki
This message was posted via http://www.satelliteguys.us by Vicki
B
RE: [VOOM] Facts and Speculation
M
[VOOM] Help AVS
