Re: [VOOM/DISH/OTA] Got Voom bix from eBay, won't get locals on scan | SatelliteGuys.US
R
rauls4
Guest
Yes.
The signal strength registers very well. Its the scanning that fails.
For example my PBS station frequency shows a 90+ signal level on the Voom box but fails
to be picked up on the channel scan.
All the channels come through when I connect the antenna cable to the Samsung HDTV
tuner so I know the antenna is properly aimed and wired.
--- In VOOM@yahoogroups.com, Dave Lay <dlayphoto@s...> wrote:
> Did you try to aim the off-air antenna?
> --Dave
> On Jul 6, 2005, at 10:07 PM, rauls4 wrote:
> > Signal strength is good but cannot watch any of the channels.
> > When I run the Scan Local Channels none is listed.
> > Item 5 (Activate Box) is unchecked.
> > Seller said in listing:
> > "I HAVE VERIFIED ALL HDTV OFF AIR CHANNELS ARE RECEIVED."
> > How is this possible?
> > Any help is greatly appreciated.
> > Raul
> > YAHOO! GROUPS LINKS
> > ▪  Visit your group "VOOM" on the web.
> > ▪  To unsubscribe from this group, send an email to:
> >  VOOM-unsubscribe@yahoogroups.com
> > ▪  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service.
> [Non-text portions of this message have been removed]
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
I don't know where you reside. I also have same problem with one of local PBSs. After contacted the station, they suspected the header of the signal stream may be the problem; they are in process of moving from channel 27 to 25, they don't expect to solve this particular problem (only to Voom Motorola) any day soon.
R
