Searching for SAT on certain HD channels on all HD units | Page 2 | SatelliteGuys.US
DO let us know what he found. He may well throw several things at it at once- which sometimes makes it difficult to tell what exactly fixed it. Usually not time to do single "fixes", bring receiver back up (reset necesary sometimes)-replace another part/check..replace another/check. If he pulls LNB and sees a connector that looks marginal he will probably replace it and the LNB at once and probably peak the dish while he's at it. If there is a jumper on the LNB he may replace the barrel and weather boots. I would. If that cures the problem you really don't know if one or any of the others alone would have done so.....and it doesn't matter.
Now that the Vikings season is toast....
Is there a way to turn off TVMail?
