And we haven't heard from him since then... :yikesGeneWildershair said:I went ahead and did a factory reset. Don't know if it will do anything, but we'll see.
Jay, are you still ok?
"We will see," said the blind man!!!!!-I want my DVI connection back-hurry wilt-mili-second blackouts forced a change to comp. for now.rang1995 said:from Wilt on the Yahoo board
"We're close to a fix, I'm told, on the black screen issue you guys reported and the "missing" channels should be back.
Talking days her for the fix, I'm told.
Wilt
Ilya said:And we haven't heard from him since then... :yikes
Jay, are you still ok?![]()
eschu97611 said:"We will see," said the blind man!!!!!-I want my DVI connection back-hurry wilt-mili-second blackouts forced a change to comp. for now.
Talking days here for the fix, I'm told.
Wilt
"Be quick, but don't hurry"-John Woodenandrzej said:No, please don't hurry Wilt. Take your time to do it right.![]()
Can you or someone else confirm that the black-out problem is only happening over DVI? I thought I saw it over component connection too, but I am not positive...mvitoff said:... I have since unplugged DVI from box and went to Component.
On my setup I get blackouts every minute or so using DVI (my display IS hdcp compatible). When using component, it works ok.Ilya said:Can you or someone else confirm that the black-out problem is only happening over DVI? I thought I saw it over component connection too, but I am not positive...
Limited time offer
