That's ok! I like to hear an intelligent man talk.Can't stand to see you talk to yourself like this
I have been trying but have only had modest success. I can't get the channels to display longer than a couple of minutes, and when I change channels, the satellite changes because the signals vary, but the new channel won't display. I see good signal, just no picture or sound.From what I can gather, you are now trying to get MT to work?
Maybe you can help me with whatever I am doing wrong!I've used all the others, but always MT is the one I use daily. It is rock solid.
The latest version of Channel Master would not export my Pansat list to the MT fomat, that's why I looked it up on the MT forum, and the advice from Saar was to first scan in a few channels from MT, pull them into Channel Master which you can then create a template from that, and then the export should work.As for channel lists, you can blind scan with any stb and easily dump that list into MT from Channelmaster. I've never found a need to use a template but may have been lucky with the stb's I'ved used being supported.
My card is the 2.6d card which could account for the difference.
I have had DVBDream loaded for about 15 minutes prior to this post and using the Raw Diseqc commands from JerryT, The C-Band LNB on port 2 of my switch works great.
BTW, here are the Raw Diseqc commands as written by JerryT if anyone here needs them:
Committed lnb1 raw command E0 10 38 F0
Committed lnb2 raw command E0 10 38 F4
Committed lnb3 raw command E0 10 38 F8
Committed lnb4 raw command E0 10 38 FC
(Uncommitted lnb 1 to 16 in Mytheatre)
Uncommitted CMD 0 raw command E0 10 39 F0
Uncommitted CMD 1 raw command E0 10 39 F1
Uncommitted CMD 2 raw command E0 10 39 F2
Uncommitted CMD 3 raw command E0 10 39 F3
Uncommitted CMD 4 raw command E0 10 39 F4
Uncommitted CMD 5 raw command E0 10 39 F5
Uncommitted CMD 6 raw command E0 10 39 F6
Uncommitted CMD 7 raw command E0 10 39 F7
Uncommitted CMD 8 raw command E0 10 39 F8
Uncommitted CMD 9 raw command E0 10 39 F9
Uncommitted CMD A raw command E0 10 39 FA
Uncommitted CMD B raw command E0 10 39 FB
Uncommitted CMD C raw command E0 10 39 FC
Uncommitted CMD D raw command E0 10 39 FD
Uncommitted CMD E raw command E0 10 39 FE
Uncommitted CMD F raw command E0 10 39 FF
Information from Eutelsat; Bus Functional Specification Version 4.2 Section 8 Definition of Diseqc Bus Commands. Page 13.
E0 is the frame bite, first transmission.
10 is the address bite, any switcher.
38 is Committed switch command "Write to port group 0"
39 is uncommitted switch command "Write to port group 1"
F? is the data bite. This has to be the command for each port.
Thanks Jerryt, and thanks to you Starman for not letting me talk to myself.
