Can you point me to that list? I'd like to see it.Greg Bimson said:One of the other forums posted the tentative list of markets the Spaceways will serve by the end of June, 2006. There were quite many markets on that list.
However, I don't expect turning Spaceway into one big CONUS spot. It is counter-productive.herdfan said:If they are really just going to turn the Spaceway's into 1 big spot, then I can "move" to what ever city I want in my half of the country. For example, I have relatives in Indy which is scheduled to come on line on 4/1. If it is one big spot, I can get Indy locals here in WV.
Greg Bimson said:However, I don't expect turning Spaceway into one big CONUS spot. It is counter-productive.
I'm going to explain how they are going to use these two new satellites which are SW 1 & 2. They will be using these two satellites as two big spotbeams. One satellite for the western US and another satellite for the eastern US.
herdfan said:Nor do I. It would be a horrible waste of capacity. But I am not the one who said it. Longhorn did in post #35 Specifically:
I don't think what he was told was incorrect, but I think it was either partially told or misinterpreted.
Where 7S can accept uplinks from 4 locations (IIRC, but it may be 8), the Spaceways can accept uplinks from 112 locations. That means each transponder, or in the case of Spaceway, each 36mhz band can be used 112 times. Now this would be overkill and I don't know that you would need to reuse it that often, but it would be possible.
The Spaceways do not have CONUS capacity as well know if from other D* satellites. They have a phased array antenna with many different configurable spots. So they can be configured to cover the CONUS either by making each spot bigger and therefore using more power, or they can use several smaller spots each with the same programming. But then these spots lose the ability to be used for anything else and the uplink benefits.
Since it has been announced, and does seem logical for STSF to be in MPEG-4 next year, the Spaceway's will need to be able to deliver some form of CONUS signal. Here is where the concept of the 2 Big Spots come into play. Each Spaceway will use perhaps 12 transponders (A SWAG), or 36 mhz bands, to cover half the country. They will each provide the same programming. But the Spaceways will be able to reuse these transponders on the other side of the country as spot beams. So lets say for example, transponders 1-12 are used to supply national channels to the east coast, they can't be used for spots on the east coast. But they can be used, based on the Spaceway uplink capacity 111 more times on the west coast. And extreme example, yes, but it makes the point.
So lets say it takes 10 spot transponders to cover the country as a CONUS beam would, those transponders are lost for any other purpose. D* has 48 transponders at each slot 99,101,103. But since the 101 is only being used for internal D* purposes, I won't count it. So there are a total of 96 transponders, but if it takes 24 of them to cover the CONUS, then 25% of the total bandwidth is being used for National channels. (Fine by me, but D* execs tend to think differently). So if you take the 4 uplink centers that I know of, you have the ability to have 312 effective transponders. (72x4)+24=312. Given previous statement that Spaceways will have the capcity for 700 HD channels, then 700/96 = around 7-8 channel per transponder which is about right considering MPEG-4 is supposed to be twice as efficient and so is the 8PSK modulation. So lets just say 7 channels per transponder or one market with the big 4 a couple of netlets and an RSN (which really needs to be CONUS, but we will ignore it for this example)
So if Spaceways were to be used for nothing but locals, then in theory they could handle 96 markets of 7 channels each. But throw in using 25% of the transponders as CONUS, you drop to 72 markets. Consider that the bigger markets will have in excess of 10 channels and the number drops even farther.
But if each Spaceway dedicates 12 transponders to doing CONUS on half the country, then you get to reuse those 12 transponders 3 more times (4 uplinks) on the other side of the country. This is a net gain from both Spaceways doing the same thing of 72 transponders that can be used on the other side of the country from the half CONUS beams.
These number were used as an example and may or may not compare to the actual numbers, but the theory remains the same.
tibber said:Some givens:
The Spaceway birds were primarily designed for Directway internet use and not primarily for video. Amazing capabilities in uplink and spotbeam features.
Using them long-term for CONUS is somewhat wasteful.
Directv 10 and 11 are primarily designed for video, more conventional mixture of both CONUS and spotbeam capabilities.
D* will be required to support more HD, certainly by 2009--though it very easily could have been 2006 had Congress and FCC pushed a more aggressive digital timeline.
So from all this and all the comments well said in this thread I'm wondering if the timeline/plan is something such as:
Now: Bring up HD LIL on the spaceways (ok, this is also a given, we're watching that happen in Detroit and the lucky 12)
Jan: (After NFL is done) release that CONUS Mpeg2 for new CONUS HD chans
Mid 2006: waste some spaceway capacity for even more CONUS HD (if there are chans to launch that is...)
Fall 2006: waste some more spaceway capacity for NFL STSF in MPEG4 (meaning all us STSF users will have to switch even before our DMA HD LIL launches.)
2007: launch Directv 10 and 11
later in 2007: CONUS moves off Spaceways onto Directv 10 and 11
In other words just a short-term waste of the spaceway capabilities, and somewhat in line with how fast D* can really deliver HD LIL to the nation in terms of installing new dishes, receivers, etc.
And this plan supports all the insights LonghornXP and others have been sharing with us. Thanks, btw!
Did I miss something (quite likely, I'm willing to admit.)
Cheers,
Tom
Of which up to 14 of which will be reserved in some form for STSF given that all games are supposed to be in HD in 2006.LonghornXP said:while they will have room for the last 50 on the two spaceway sats.
Barneypoo69 said:Another delay.........whats new....![]()
Barney
herdfan said:Of which up to 14 of which will be reserved in some form for STSF given that all games are supposed to be in HD in 2006.
tibber said:Jan: (After NFL is done) release that CONUS Mpeg2 for new CONUS HD chans
LonghornXP said:Actually very few transponders will be needed for this for two reasons. It seems that more than 3 HD channels can fit on a transponder. The second reason is what not all the games are on at the sametime. I think they will only need three or four transponders for all the ST games once they are all on spaceway.
Limited time offer
