Suggestions for FTA HD PCI Card and dish for a HTPC system | SatelliteGuys.US
calguy99
5
Hi, I am building a HTPC system and I am thinking about adding a FTA PCI card to my build. I was wondering if anyone had suggestions on which card and dish would work with Windows 7. I want to record HD programming for playback on my HD TV and wanted to know if the Win 7 OS will do that. Thanks Joe
I'm very happy with the Prof7301 that Rick sells. It performs like a champ on my HTPC (WIN7 64bit, i5 processor) with both SageTV and ProgDVBPro.
proftuners.com might get it to you cheaper if your a canuck.
crackt out,.
Hi thanks for the reply to my post. Are there any satellite dishes which are better for HD TV? thanks
a dish is a dish and bigger is always better. youll probly get the most hd from cband so you would need a 6 ft or bigger dish. 10 foot would be recommended. there are some ku hd channels you could get easily with a 90cm dish as well.
crackt out,.
Hi thanks for the reply a 10 or 6 ft dish would be way too big for my roof so a 90cm dish would be the way to go. Are there any newness sites to help me set and point a dish. Thanks
36" vs 39" dish
Satcom Resources
