Switch Question | SatelliteGuys.US
Switch Question
Mr_J
12
I have a Dish 500 with Dish Pro Quad LNBs.
I would like to use a single coax cable for both tuners.
Are there any other alternatives to using a DPP 44 switch or upgrading to a Dish 1000?
Thanks,
John
Not really. To feed a dual tuner with a single cable you need Dish Pro Plus technology. Your options are a DPP44 switch, a DPP Twin and you could get a Dish 1000.2 that comes with a triple lnb that can feed 3 dual tuners.
Thanks,
John
What receivers do you have that are currently running off that quad lnb?
That is what I want to know what receivers do you have?
I have a 501, 721, and a brand new 622.
The problem is that there is only one coax cable going to the 622 location and no easy way to add another.
Thanks,
John
622 and DD 5.1
522 DVR Receiver lost signal...
