Timer Schedule, TimeTrax 1.4 only records 0 to 5 tracks | SatelliteGuys.US
teeb61
7
TimeTrax Recast v1.4
When I try to record an XM channel using Timer Schedule, TimeTrax will only record around 1 to 5 minutes/0 to 5 tracks before TimeTrax no longer receives audio even when the recording schedule is set for an hour. I close TimeTrax and re-open it, but there is still no audio coming from TimeTrax and I have to reboot the computer to get TimeTrax Recast to produce audio again. This behavior is reproducible and happens every time I try Timer Schedule.
When TimeTrax does lose the audio, I can still playback other audio such as my TV tuner card, CDs etc.
Sounds like it could be a radio hardware or stream problem. What are you recording from? Hardware or XM online? If hardware, which hardware are you using?
David K.
Time Trax
Hi there:
Audio card is Creative Labs SoundBlaster Audigy 2 ZS.
It's only when I attempt to record that I lost audio after a few minutes. If I'm just listening to XM using TimeTrax, I've listened for hours with no audio loss.
Thanks,
Tony.
Got a few more specifics on this:
When I try to record an XM channel using Timer Schedule, TimeTrax will only record around 1 to 15 minutes/0 to 5 tracks before TimeTrax no longer receives audio even when the recording schedule is set for an hour.
The same behavior occurs when I try manually recording (non-scheduled).
If I close TimeTrax and re-open it, there is still no audio coming from TimeTrax and I have to reboot the computer. This behavior is reproducible and happens every time I try Timer Schedule.
I tried turning on or off the XM-Online settings for the channel listing and it makes no difference.
I do not have a screensaver installed.
Sound card is Creative Soundblaster Audigy 2 - plugging into the line-in.
Is there any further information about this problem??
I am building a new machine and it will have this sound card in it so I wanted to know if anyone else is having trouble with this or is it just this person?
tee - do you have a support ticket open? before I do any escalation I'd like to review what has been tried thus far.
If you do not have a ticket open, please create one.
David K.
Time Trax
Timetrax 1.4 won't connect
Can not load drivers
