Upgrade from Dish 508 to 721 | SatelliteGuys.US
gasman882001
697
138
Houston, Tx
I currently have two 508 receivers in my house. I Am thinking about replacing one of the 508's with a refirb. 721 so that my wife can record two shows at a time and then watch something recorded previously. I am not interested in HD at this time so that is why I am looking at the 721's(no monthly pvr fee). My question is this.
Should I be able to just unplug/deactivate the one 508 and just plug the 721 in and activate and be ready to go or do I need to have additional equipment installed for this line?
Any help would be appreciated.
BobaBird said:
Or you can replace whatever's on your dish with a DishPro Plus Twin and get a DPP Separator for the 721. No additional line needed.
Correct, *if* your cabling supports the higher frequencies required to use DishPro. Last summer I tried to replace my Legacy Twin LNBF with a DishPro Twin and DP34 switch to get the three lines I needed for a 508 and 721 (721 did not support DishPro Plus at that time). I could not get this to work, even though the original install used sweep-tested RG6 cable. I ended up having to get a Legacy Quad LNBF and run a 2nd line to the 721.
Just keep this in mind if you are considering upgrading and are not already using DishPro equipment.
philly locals
622, Simultanious HD output on HDMI and Y/Pr/Pb?
