[VOOM] Final question from newbie - why no PPV on VOOM? | SatelliteGuys.US
S
seattlesatelliter
Guest
[VOOM] Mike, actually VOOM does have one PPV called "Playboy Hot HD".
One guess as to what's on there. Maybe this is the channel that is
keeping them going financially! Don't know what's on it as haven't
subscribed.
We would like PPV as well. Would be happy to pay for new movies.
Assume this will be part of the new 70 HD channels in March and DVR
set for the "first half of 2005" update to the service. We'll see.
Maybe something will be announced at CES.
Watching HDTV under tapering off rainy (hey, it doesn't rain all the
time) Seattle skies, Gill
--- In VOOM@yahoogroups.com, "snidely9447" <snidely9447@y...> wrote:
> See subject line. Even DISH has one HD PPV channel and they charge
> $6! D* has one and charges $5. Our BEV system has FOUR! They
> charge $5Cdn. Seems to me it would be a good source of revenue for
> VOOM to have PPV. They are the only system that doesn't.
> I notice D* has an "X" rated HD PPV channel that they charge $15
> for 3 hours worth of whatever it is they show.<G> [Guess they
> probably "show it all"]
> ...mike
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Re: [VOOM] Mike, actually VOOM does have one PPV called "Playboy Hot HD".
HD PPV! I second, or third that one.
----- Original Message -----
From: "seattlesatelliter" <seattlesatelliter@yahoo.com>
To: <VOOM@yahoogroups.com>
Sent: Saturday, December 25, 2004 7:37 PM
Subject: [VOOM] Mike, actually VOOM does have one PPV called "Playboy Hot
HD".
> subscribed.
>> ...mike
> Yahoo! Groups Links
$4.98 domain names from Yahoo!. Register anything.
http://us.click.yahoo.com/Q7_YsB/neXJAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
...mike
Yahoo! Groups Links
VOOM has Porn. :)
VOOM should have PPV in March, they just updated the software on the receivers to support PPV. So it will be here soon. :D
new channels
i hope voom will add these NEW CHANNELS IN MARCH 2005
ENCORE WESTREN CHANNELS
WGN-HD
KTLA-HD
CMT
GAC
G4TTV
this is the DISHBOY, my install for voom be on 12-29-04 at 1 o clock in
the after noon, all they need to do is take down my 61.5 dishnetwork dish.
Scott Greczkowski said:
VOOM has Porn. :)
Have they actually announced that it will be available in March?
voom install next week
hi i get a VOOM install next week ,the cables is already run .I am useing
my outdoor antenna it is TELEVES PRO -75 .all they have to do is
take down my 61.5 w dishnetwork dish. install new one,my install is on
12-29-04 at 2 o clock with 1 receiver.
I HOPE I GET A GOOD INSTALL
Baring bad weather, I don't see why your install shouldn't be a simple in-and-out procedures. Just a couple things to consider:
1. If your dish on the roof or in a hard to get to area, I hope you don't live in the snow belt. Of course that may now be Texas!
2. I will assume that you have separate RG-6 for your antenna?
3. How many receivers will you be installing? If more than one, do you have an amplifier/distribution system running to your other receivers?
4. If you have an existing multi-switch in place with your E* system, I would pull it out prior to your install just so the installer isn't tempted to reuse it. Although I have separate coax for my Channel Master antenna and to all my receivers, VOOM installed a Winegard model# VM-3400 power passing multi-switch free of charge - this may be much better than an older, weather-beaten multi-switch you may have in place.
Anyway, good luck on your install. Please post the results.
[VOOM] Re: Final question from newbie - why no PPV on VOOM?
Well, if they are going to use the PPV function than they are going
to have to have a software fix first. My phone lines are
disconnected from the VOOM box, because the boxes freeze constantly
since the last update when the phone line is connected. I think the
phone line must be connected to use the PPV.
Scott
--- In VOOM@yahoogroups.com, Scott Greczkowski <satguys2004@y...>
wrote:
> VOOM has Porn. :)
the
> Scott Greczkowski
> This message was posted via http://www.satelliteguys.us by Scott
Greczkowski
Yahoo! Groups Links
--- In VOOM@yahoogroups.com, jagouar <satguys2004@y...> wrote:
> Yep the Encore Westerns channel is the one keeping my grandparents
from
> voom.
> ** LET THEM KNOW THAT STARZ PEOPLE CAME TO VOOM! AND GAVE OUR SOME
LITTLE ADVER: AND IT SHOWS ENCORE WESTERNS SO IM CROSSING MY FINGERS
WE GET THOSE SOON!! KEEP IN TOUCH WITH VOOM! WERE ALWAYS ADDING
SOMETHNG NEW ALL THE TIME!!
LINKINKORN_KID****************************************
> jagouar
> This message was posted via http://www.satelliteguys.us by jagouar
Yahoo! Groups Links
Both VOOM and Dishnetwork use the same bird at the 61.5 location.
If your dishnet antenna at 61.5 is using a legacy LNB, they can use the same dish, if it is using a DishPro LNB (does Frequency stacking) then they will have to use the voom dish or just change the dp-lnb to a legacy type on the dishnetwork dish. Another option with a dishpro lnb is to use a "Dish Pro Adapter" at the VOOM STB. This will convert the frequecy stacking back to a legacy setup before the signal enters the voom stb, they cost about $60 for the adapters.
from
> voom.
> jagouar
No they don't, same location, different bird.
RE: [VOOM] voom reciever problems
H
[VOOM] A question on remote use.
