[VOOM] Re: Is the Guide Down? | SatelliteGuys.US
L
lee_kee_brain
Guest
[VOOM] Is the Guide Down?
I've had no guide since last night, Are they fixing something?
I had no guide either today but I did a soft reboot and it came up pretty quick. First time it has happened to me.
Do a receiver reset. If that doesn't work, unplug the receiver for 10
seconds then plug it back in.
I had no guide, did a soft re-boot and still have no guide after 20 minutes. How long should the guide take to download with the new software?
No guide data when I got home at 5pm, I rebooted and have it now. Didnt time it but since its 5:20pm it took less than 20 minutes.
No guide data since this morning.
What is a "soft reboot" and how do you do it?
I'll unplug and replug for now then check guide later when I get back home.
Uplugging, waiting 10 seconds is a hard boot.
Holding in the power button until the screen goes black and than releasing is a soft boot.
I had to a soft reboot on both my receivers yesterday to get the PG to load. All is running fine now.
Re: [VOOM] Is the Guide Down?
ddlsmith
This message was posted via http://www.satelliteguys.us by ddlsmith
software?
jnardone
This message was posted via http://www.satelliteguys.us by jnardone
vurbano
This message was posted via http://www.satelliteguys.us by vurbano
home.
MNHTUG
This message was posted via http://www.satelliteguys.us by MNHTUG
jimmykce1
This message was posted via http://www.satelliteguys.us by jimmykce1
B
RE: [VOOM] Facts and Speculation
M
[VOOM] Help AVS
