[VOOM] VOOM Service | Page 2 | SatelliteGuys.US
[VOOM] VOOM Service
[VOOM] Re: VOOM comment, and a question
The mystery button controls the settings of the box.
If you pop it and all four amber lights go, it's in Native mode.
Which means the box gets to chose 1080i,720p,480i or 480p
Top light is 1080
2nd 720
bottom two are 480
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
RE: [VOOM] comment, and a question
My Sat signal is 95 / 96.
My OTA signal is never the same.. 1,3,5,9,21,56,61, always changing...
My current software version is 00.05.68 << is this current?
Pete
At 08:09 PM 7/10/2004, you wrote:
>Press the VOOM button on your remote, then the green button. Then go to
>the last option and continue till you get to the signal strength. What is
>it? My Sat signal is around 97 while my OTA signals on all but ABC are
>80+. My ABC sat signal go from 55-75 and I know that's why I'm having a
>pbm with my ABC reception.
>Basically from what I can tell, if your signal (for voom or ota) is below
>75, there will be reception issues. .. atleast that's what " I " am finding..
>So what's your sat signal?
There you go.. OTA signal that "reaches" 61.. no wonder you have problems..
you need an OTA signal of atleast 70 minimum. Over 80 and you shouldn't have
any issues at all unless it's a hard rain. Over 90 and it'll stay on even
during a good rain. Under 70.. especially under 60 and you can forget it. So
it sounds like you either need an amp or a omni directional OTA.
HTH,
Robert Heitner Jr.
Data Developers Plus, Corp. http://www.ddpcorp.com <http://www.ddpcorp.com/>
Home of DDP's Contact Manager http://www.ddpcontactmanager.com
<http://www.ddpcontactmanager.com/>
_____
Sent: Saturday, July 10, 2004 9:42 PM
To: VOOM@yahoogroups.com
Subject: RE: [VOOM] comment, and a question
Pete
Press the VOOM button on your remote, then the green button. Then go to the
last option and continue till you get to the signal strength. What is it? My
Sat signal is around 97 while my OTA signals on all but ABC are 80+. My ABC
sat signal go from 55-75 and I know that's why I'm having a pbm with my ABC
reception.
finding..
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129ipt71t/M=295196.4901138.6071305.3001176/D=gr
oups/S=1705036932:HM/EXP=1089600149/A=2128215/R=0/SIG=10se96mf6/*http://comp
anion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=
:HM/A=2128215/rand=709894853>
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
