w00t! Finally got my system (mostly) complete! | Page 4 | SatelliteGuys.US
Iceberg said:
If there were posts deleted, I would be able to see them. I don't see any posts that were deleted.
I'll stop using the quick reply and see if the problem goes away...
Shawn
Ok... well, I have the new reciever in place, and I noticed that some channels have decreased in quality by a few percent.. however, my readings are much more stable than they used to be.
For example, on The Tube, I am getting 70-72% signal, and a solid 40% quality.. it hasnt budged one percent either way..
Keep in mind, that I have very heavy cloud cover at the moment, and I am currently unable to move my dish to fine tune the signal.
Picture quality seems to be a bit better too.. I will have to hook up the Svideo to get a really good comparison.
I will have to paperclip the motor again, but my roommate is asleep at the moment (its his bedroom window that I have thru to get to the dishes
I was getting anywhere between 40 and 60 before.. its just odd that it hasnt moved from 40 in the 5 minutes I was watching it...
grr.. ok, this sucks.. must be a bunk motor.
reciever is in place, working fine, I setup the newest legal firmware on it, did a factory reset, went to the dish, motored it manually to AMC6 (truesouth) and paperclipped it.
One thing I noticed is... my truesouth should be 0.1E.. but it is most clearly W of center on my motor.. like 1.0 or 2.0W.. I would think that would screw up my arc, but it tracks alright.. (that is, when it moves)
I will say, that while paperclipping the motor, the light does not go back to green during the process.. only to orange, and stays there.
Alright, I am sick of this.. hah
PSB: you got yourself a PM, gonna order a motor and C-band lnb from you.
Odd... does the Fortec Star Lifetime (not Ultra) not have Blind/Power scan?
It looks like there is a way to load Pansat 2300a software on here.. does that have blindscan? I cant seem to find any reviews/specs for either of these.
Well, I answered my own question, the 2300a and Lifetime (non-Ultra) does not have blind/power scan..
I guess this is more motivation to fix my Pantec correctly.
In better news, I recieved my SG2100 from PSB yesterday, just installed it, and lo-and-behold, USALS works! friggin clone motor....
I noticed that most of the settings were quite different.. I should take some photos of the motors side by side
I think I am going to have to touch up my polar mount on my dish with some primer.. theres a few shiney spots where I have had to adjust the elevation several times.. same on the polemount from changing and adjusting the motor..
Now I just need to get a new DiSEqC switch, and I should be all good to go.. heck, I can even put up a second motorized dish now (albiet without USALS) then again, USALS has limited use, due to its non-preciseness (is that even a word?)
hmm.. this should mean I would be able to put that universal LNB back out there too...... hmmmmm...
Ok, now that the Franken-ciever lives again.. It was time to "finish" my system.
My Invacom showed up yesterday, threw that on the F* 80P, and the DMSI SG2100. did some fine tuning on the motor setup, now I am getting high 40s on G10R, and I am tracking the arc just fine from G10 to PAS9..
I think the next purchase will be a F* 90P, and then move the 80P to a permanent G10R position.
Then I have this Channel Master 1.2m dish to try to point at G3C for the AC3 version of The Tube on C-band..
All of the pieces are falling into place.. 4 dishes, 5 LNBs, and 3 recievers later ;)
I have run into a bit of a snag...
when I updated the software to the newest Pansat 2500a image, I seem to have lost the "bump" feature in DiSEqC 1.2... looks like the same with the Fortec Star Lifetime Ultra software...
Did they remove it? that was such a useful little feature.. I cant see any logical reason for them to remove it.
I also found out my arc is wrong, I have excelent signal (high 40s low 50s) on G10R, but I am only getting 20-30 on G3C and further east is dead.. looks like the azi is off a bit (too far east), and the dish elevation is a tad too high. So I guess I am gonna be redoing my aiming tomorrow morning..
Just had to take care of that exact problem here.
It seems like a pain, but oh how nice it is once it's fixed :D
That's really odd... that's the only reason I use 1.2, for the nudge feature.
I guess one of the images loaded on this box has changed it.. Its still there, just not its own line.. if you just touch left or right on movement for a second, it does a nudge, if you hold it, it does a move. not sure why it suddenly changed, even with the oldest firmware I can find, its like that now (2.24) unless I am smoking crack, and I am just imagining this function....
I played around with my motor, and I have the whole arc, but I lost a few quality points on my western sats by doing it, but at least I gained the eastern sats again..
Ok.. it looks like I have everything together.. Moved some stuff, and rewired my living room.. Replaced my 80P with a 90P.. I have some slight fine tuning to do, but all in all, its together.
Photos follow:
stepped on pete?
The Laser printer is there, because its the most central location in the house.. when you live with 3 other computer geeks, you cant really put the printer in any one room ;) and of course, its the Dell 3100cn, which we bought for $329 shipped (cant go wrong with that!)
At this point, I dont think I can give up my Starchoice.. I actually dont even have my cable hooked up at the moment, and replaced it with the DSR500 Gotta love TMN and CBC
Very cool. I might have to break down and go with a broker.
Its definately worth it.. PM Iceberg, he has details on a good broker..
I just finished watching the Red Green show on CBC... Thats the best thing about *C, so many local feeds that you can always find something on.
yep..love Red Green
same show on at 10:30, 11:30, 12:30, 1:30 & 2:30 Central Time
On Mondays, CBC Prince George (325) has it on at 4:30 Central :)
IA-8, 89*west is now testing........
