Xenforo Upgrade | Page 21 | SatelliteGuys.US
Xenforo Upgrade
Here's the screen from the Edge browser:
I cleared the cache and tried Firefox, Edge, IE and Waterfox and they all look the same. I'm running the latest version of Windows 10 1909 18363.426.
It looked just like your's until earlier this morning.
Collapse the sidebar and see if that helps.
It has to do with your screen size. I just minimized screen then then kept adjusting the size of the box and finally it looked like yours. I bet if you collapse the sidebars you will be back to normal. :)
UPDATE --- Actually nope that dosen't work...
Looks like I will have to remove the sidebar from the topic listings page. :(
Reactions: charlesrshell
I've got the sidebar collapsed by default on all pages. Just tried my laptop and I see the same thing. It was fine until the sidebar button appeared this morning.
I'm having some trouble creating clickable web links. Did something change about the ... syntax?
No changes have been made there. I just posted on a few minutes ago.
If you still have trouble try PMing me the link and I will see if I can post it with my various test accounts.
It's still part of the site. That's like saying that the Home Theater likes shouldn't count
Because people's political rantings have no relationship to their technical credibility. This is Satelliteguys and politics shouldn't have anything to do with credibility here.
IMHO 'The Pit' is a huge waste of time.
Sent from my Pixel 4 XL using the SatelliteGuys app!
Reactions: TheKrell
I beg your pardon but it's not the same. Likes in the Home Theater thread would indicate that the person has credibility in that field, likes in the Pit mean absolutely nothing except that somebody else is as crazy about your ploitics as you are. :biggrin
Reactions: Keith Brannen
I don’t think it does anything as we don’t have the post it info collapsed since it only shows post count and your location.
There are 15 things that could show there but we only show 2, so I don’t feel a need to collapse them.
I selected postbit in Preferences and it works now since you have added the items under the avatar.
In the "Mark forums read" you use to be able to mark all forums (as it is now) or only select the current forum you are in. Any way to bring that back?
As well, there use to be a new post count "bubble" nearby it, which I found helpful (especially since I automatically go the the FTA forum to start).
