I just noticed the satellite number is back on the second info screen in S238.
All of the VIP models and hopper should be reverting back to my channels, that is how it is designed to work. That was a change made quite some time ago.
Why would this be a default behavior? If a customer selects a list other than "my channels" or a custom defined list, then why change anything? It would be the equivalent of desktop shortcuts. If a shortcut is added to the desktop by the user, it should stay there until it's removed by the user. Using dish's logic, the desktop would be wiped clean after a reboot of the computer.
The little apps menu on the bottom of the screen still won't leave gracefully. You still have to do another function like viewing the guide to get it to stop looping the apps menu.
s238 and I still lose my end. Also, this morning the guide was on my channels. I can see why dish would want it to revert for noobs that might get confused but they should offer an expert option that would leave such settings alone. I only want to look at my favs, rather than all the crap that I have to get with my tier, but that belongs to a different thread![]()
If you are using a non-Dish remote, this has been reported to Dish several times....
Thanks, I hadn't seen that. I'm using a Harmony 880....
Almost every report of that problem have involved harmony remotes.
Not sure what button the Exit button maps to on the Dish remote, and not sure why Exit wouldn't do the trick. What Dish remote button works??
Limited time offer
