I really wanted 95W Galaxy to get 4000H 30000 , 4080H 31250 & 4167V 6614 (all clear supposedly ) but it can not even see them . It only pulls in 11780 and 12050 off 95W![]()
Good to knowYou won't get those transponders on your dish as they are on C-band which requires a 6 ft. or larger dish. As a rule of thumb, you will only be able to receive 5 digit transponders (i.e. 11780 and 12050 that you mentioned) on your current dish as these are Ku-band.
Just said equipment is not able to pick up the transponders , polarities and syb rates everyone was providing .
Yeah , seemed weird here too . When I put in all the numbers suggested , I never got a Q-bar . Even tried to scan channels and nothing would lock . Thumbed through freq every 10-20 seconds until one did get Q-bar . I would set motors position for that satellite , then search . The funny thing was it scanned ' all channels ' and freq and found channels previously suggested I could never get a Q-bar or lock on originally . Finding ' S ' ones but screen being blank makes sense of course being scambled . Some channels it finds but preview screen is blank and main screen says ' no signal '. Example as 99W Galaxy 4R 12780H it found channel 00002 CCTV News or 97W 11836H 00005 Time TV . No big deal . About 54 unscambled channels it found in search but no signal in preview or to main screen , but others pull up to 99S 99QSomething doesn't sound right with this installers comment.
Both transponders mentioned for Galaxy 19 (11991 and 12152) work on all MPEG2 receivers that I have in the office. In fact am watching RT News on 12152 right now.
Glad to hear that it is working. Time to enjoy the results of your trials!
Basically used First Strike to accurately ID satellite targeted and fine tune quality signal .The receiver's LNBF LO is set to the wrong setting for 95w and probably also wrong on 97w as well. How do I know? Well, CCTV TP frequency is actually 11780 and you scanned it at 12780. This calculated to mean that the LO frequency is set 1000MHz to high.
This is very likely why you can't lock onto the other two TPs. I bet you $1 that you would get a transponder lock if either:
1. The LO setting was correct
2. You add 1000MHz to the correct frequency. Example- enter 13152 instead of the correct 12152.
You might want to read the LO Frequency - 101 FAQ if you are interested in learning why the LO frequency must be set correcting to lock onto downlink frequencies.
Good Luck!
Guessing I should wait until I have time to copy down all the settings before deleting . CCTV News 11780 on 97W , CCTV News 12780 on 99W , CCTVF 11780 on 97W , Time TV 11836 on 97W , CCTV-E 11780 on 97W , CCTV-E 12780 on 99W ect ect . Oddly I get other channels on those same satellites and transponders .Are you receiving CCTV on 95w at 12780? If so, the LO setting for 95w is incorrectly set. Try deleting all transponders on 95w then performing a blind scan. Tell us what TP frequency CCTV scans in at. 12780 or 11780?
Don't waste your time copying down data. There is no CCTV on 97W or 99W. It is only on 95W and always on 11780 MHz, no other frequency. If you receive it on any other frequency, your receiver is configured incorrectly. Once centred correctly on a satellite, and with correct receiver settings, you can just blind scan.Guessing I should wait until I have time to copy down all the settings before deleting . CCTV News 11780 on 97W , CCTV News 12780 on 99W , CCTVF 11780 on 97W , Time TV 11836 on 97W , CCTV-E 11780 on 97W , CCTV-E 12780 on 99W ect ect . Oddly I get other channels on those same satellites and transponders .
Though it searches a transponder is it possible some of the channels scanned on that transponder are too weak for picture , but strong enough for the search to lock ???
Perhaps in the spring . Moved onto next hobby which was to double signal strength of one of the top rated long range HD antennas with my own rabbit mesh one . Signal through the forest between two mountains and across the valley went from 10-40 to 40-80 in time for FOOTBALLIt's true that services like Netflix are making network programming so readily available such that even my network series-addicted niece is happy with only Netflix and no conventional TV. The good and bad about young people is their readiness to adapt to new situations with great flixability (typo intended!). I agree that Ku-band is not useful without a motor nowadays, or a backyard that looks like a NASA launch site with many dishes. I suggest you go for an 8-foot minimum C-band dish on a motor. That would provide you with many hours of installation fun, plus show you what FTA really has to offer. Check here to get a taste of what you're missing on C-band. Don't forget to click through all 18 pages of C-band channels! And these pages don't show any feeds that are all over.
Limited time offer
